How to open a Plc5/80 program using Rslogix 5000
BTL_Man
Nov 2007
N.C.
Is it possible to save or export an RSlogix5 Plc5/80 program in a way that it can be opened using RSLogix5000..?
Are you tring to open a PLC5 file for editing? If so, then you need RSLogix 5.
If you are looking to convert the code to ControlLogix, then you could "Translate" the PLC5 program to ControlLogix. Look under the Tools tab, then Translate PLC5/SLC.
It's pretty straightforward. In Logix5 save your file as a .PC5 file. Then do Tools-> Database-> ASCII Export and ensure that under the AB6200 tab you're exporting the Address/Symbol as a .txt file
In Logix5000 do Tools->Translate PLC/SLC and fill in the blanks. Don't expect to get 100% done for you, there'll almost certainly be a list of exceptions to go through. Then in Logix5000 do File-> Open but remember that you're looking for a .L5K file rather than .ACD. You'll be asked if you want to import, you won't get anywhere by saying no!
But even then it won't be a PLC 5/80 program anymore. It'll be a program for a ControlLogix. And the addresses will be all messed up. And some instructions won't convert nicely -- or won't look like they used to in the 5/80.
Have a file that a technician had on a floppy disk in one of our plants. It is a machine that a outside integrater was used, and integrater now no...
3,395
GitHub Link: Open Industry Project This is a side project I've been working on for some time. The goal is to provide an open platform for...
121
i have 2 backups: *.PVC and *.pvd file types thanks in advance for any help
163
hi All Can you please help me to find the right software to open Zip backup of 434 12A PLC? Any major steps I need to know when opening? Regards
109
197
