how to power SLC 5/04 using other power supply
alin_nst
Jan 2010
Bucuresti
Hello,
I have a little problem. I have a SLC 5/04 and the power supply 1746-P2 used with 4 slot chassis. The power supply is broken and I want use other supply. Where I can find the wiring of the chassis with the power supply? It is possible to use other power source?
You want to open up the power supply and use multiple external power supplies to give the backplane the power it needs? Or do you just want to remove the 1746-P2 and put a new 1746-P2 in its place?
Hello Tharon,
Yes, I want to give the backplane the power it needs. The 1746-P2 is burned and I don't have money to buy another one.
I recall measuring 3 different voltages at the right edge of a backplane in order to prove a power supply was okay, and the backplane suspect. We butchered a digital card and dangled test leads from it.
IIRC, we found print on boards or in a book to identify the connections at the backplane, which I suppose could be followed back to the left edge connector.
I would expect this has been done before.
I would not even contemplate this.....]
The power supply was designed FOR the SLC, and doesn't only provide power, but also provides signals to the backplane that it is powering-up. This is used to reset the modules.
Without the proper signalling, you may have troubles when powering up the system
The SLC power supplies are also very tolerant of mains voltage fluctuations, and brown-outs.
I concur - eBay is your best bet
http://www.ebay.co.uk/itm/Allen-Bra...9?pt=SPS_Bus_Logiksysteme&hash=item27be12621d
http://www.ebay.co.uk/itm/Allen-Bra...t=BI_Control_Systems_PLCs&hash=item336bac30e2
http://www.ebay.co.uk/itm/Allen-Bradley-SLC-500-1746-P2-Power-Suply-/290607100370?pt=UK_BOI_Industrial_Automation_Control_ET&hash=item43a98871d2
Hello PLC friends. I've been going through a saga of diagnosing and fixing an old PLC setup that I inherited. I am learning as I go. Initial...
343
Whenever we lose power to the the machine, the PLC loses its program. But as you can see in the picture, the battery fault LED is not ON. Also...
4,738
Hi, I am having an issue on one of my station. It won't communicate after the power shutdown. If we cycle the power it is communicating , but I...
1,467
Hi everyone. I am new here in this page. This is my first post. I hope to receive the best suggestions and tips wanting also to collaborate...
2,736
Loaded a new configuration into a 5/05 and now when we power cycle it and then I try to go online I get the attached error. And am forced to do a...
5,044
