How to replace a safety output card (1734-OB8S)?
wendaiyu
Jun 2014
toronto
87
Hi, guys, how’s going?
We have an AB controller Logix5572S with safety functions. We suspect one safety output card (1734-OB8S) is defective.
Could you give us a help to how to replace a safety output card? We have not taken related training yet. It’s a little bit tough.
Thanks a lot.
The existing plant has the CLX 1756-L62 (4MB), 1756-CNB (controlnet), 1756-ENBT (ethernet ip 10/100), 5x1756-IF16 (analog input), 3x1756-OF8...
3,743
We have a Beckhoff CP6201 PC and an EK1100 module communicating with it via EtherCAT in one of our machines. Due to problems with the PC, I want...
75
Panelview 2711-K5A8. Customer has 6 of these in service connected to SLC 504’s. One has a bad backlight and I need a solution to replace it...
2,259
I’ve got some devices that are triggered by shorting pins to common. There is 24 volts on each pin and right now I am using a relay output card...
2,573
I can't replace cpu S400 416-3XR05-0AB0 BY 416-3ER05-0AB0 in PCS7 Project when using replace object to keep the original configuration in the...
1,506
