How to reset Minas LIQI location from Panasonic PLC
eotty
Feb 2015
Stockholm
Hi
I'm having a linear track controlled by a minas liqi servo and controller, when the servo is all the way to the left, i want it to reset the location.
I tried to set.
sys_diPulseChannel0ElapsedValue:= diSetValue;
This result in the numerical value is set to 0, but the servo's absolute position is still wrong.
Any help in suggestions, answers, links would be highly apreciated.
Hi, i am using DVP-14SS2 PLC, after program written to plc, when power is reset, plc doesn't run. always need to connect to pc for the run mode.
16
Hi need help why this “failure 5 emergency stop “ appears at every startup in the morning ? Have to shut off main switch at least 10 times on...
19
311
I was loading a program onto an XE1e2 PLC and it got stuck on these two windows and won't progress. It won't let me connect from the PC to reload...
76
Hi all, i have recieved some 4RF Aprisa SR+ ethernet radios from a customer to configure. Issue is that they are used and have non-default...
81
Hi Guys, I have a 1769-L24-QBFCB1 that has the OK light flashing on the embedded counter module. The manual states it is a resettable fault, but...
112
