How to reset the B&R system 2005 PLC
Henry Siswant
Feb 2013
Klaten
Dear Sirs,
I faced problem of the a.m PLC B&R system 2005
The PLC is applied on the m/c connected to the Windows NT application program.
When the app. program started, the error message "error E 4808" that describe the PLC comunication occur.
The PLC is at "run" mode.
Please, Can anyone inform me the procedure how to reset the PLC?
Thanks.
Hello,
here (link)you can download a user manual of the System 2005 CPUs. Normaly this type of CPU has a small Reset-Button protected behind the door. You need a tool to press the button as it is hidden a bit behind the surface.... Pressing the button results in a hardware reset (maybe you have to power off/on afterwards the CPU to make it run again).
For your problem you should check the LED signaling the data transfer on the CPU. if there is no blinking, the problem may be on the computer or the cable. E4808 means no connection to the PLC. Only if there is a blinking on the CPU would suggest data arrive on the CPU but are not processed.
Did somebody install/change programs on the NT-machine ? Was something changed in the enviroment of the System ?
Good luck.
br
bb
Hi all, I am completely new to PLC's and their programming, having started a new course at college. Part of the course is to write a simple...
2,103
Hi friends; i used the %SC0014,%SA0003,%SA0014,%SC0010,SC0011, SA 0009. can i reset these bits by using as %SC0010...
3,790
Hi, i am using DVP-14SS2 PLC, after program written to plc, when power is reset, plc doesn't run. always need to connect to pc for the run mode.
28
Hi need help why this “failure 5 emergency stop “ appears at every startup in the morning ? Have to shut off main switch at least 10 times on...
19
313
I was loading a program onto an XE1e2 PLC and it got stuck on these two windows and won't progress. It won't let me connect from the PC to reload...
78
