How to save values by using Memory tags in RS View 32
AB2005
Nov 2006
Lahore
318
I have created many memory tags (String & integers) in HMI in RS View 32 in which operators save the data of machine's production related. But my problem is that when I stop the project for editing, the values in those tags clear. Is it possible that the values must be saved even I shutdown the RS View?
My suggestion would be to not use Memory Tags for vairables (data) that might change... Use String & Integer addresses in the PLC, if you can.
I use the Memory Tags when I have (for example) an ingredient to a recipe whereby the ingredient name cannot be changed. I then may use this ingredient name within a parameter file.
The ingredient name cannot be changed as it is tied to a hardware item such as a valve/pump/hopper etc..
The recipe name can be changed if need be. A recipe being a collection of ingredients.
A Parameter file is used for different recipes using the same graphic..
Hope this helps
Ian
Hi all, is there a way to save the tags values in rslogix5000 ?? I mean I want to upload some tags values which contains values of different...
4,537
Hy again, Does anybody knows how to export some tag values from rslogix 500 to a .txt file ( excel, notepad, etc ) in real time ? i whant to...
3,651
Hey, How can I make sure some data in the plc does not change values during a plc stop situation or power down situation? Can I make some...
5,921
Hi; First of all, I am sorry that my post is not relevant with this forum. I have recently purchased Samsung cell phone. I have alreay saved...
77
Hello! I have a datablock in a PLC witch contains about 700 variables. I must save this data once a day on a Windows PC in a XML or CSV file. Eg...
490
