How to scale the analog values in siemens s7 400
Dec 2006
Abbottabad
can anybody help me that "how to scale the analog values" in siemens S7 400.i hv read different programmes in which the programmer used the value 27648.why we use this value in the linear equation to scale the analog values.I have searched the web but i didnt get any useful material in scaling the analog values, if anybody knows the sites plz reply where i can find the manuals for scaling the analog values using s7 400.
0-20mA = 0-27648
4-20mA = 0-27648
0-10V = 0-27648
0-27648 is the range for analogue values, everything above that value until 32648 = overflow and not linear measurement
Why not use FC105 "SCALE CONVERT". It can be found in the standard library: "TI-S7 converting blocks".
When using FC105 you don't need to worry about the 27648 value. Just read the help file and you are on your way.
hi i am using simatic s7.i have some known values of analog input b/w 4-20 MA,with this how to scale these values using fc105(simatic s7) to get...
3,160
Hi, I'm using a Micrologix1500 and it doesnt have the SCP (Scale with parameters) block. I have a 1769-IF8 analog module and need read the inputs...
3,776
Hi I'm trying to change the scale in a analog Input module in the module while online. I got a warning saying something like Module changes could...
2,075
I have an automated batching system that im using an analog scale to trigger automated valves to open and close. I have the programming done and...
2,362
Please help me... Is there any possible way to use AB IR4-1762 module for analog input scaling....?
1,191
