How to setup Citect V5.2 Display client on two I/O Server Redundacy
atmojapele
May 2012
Klerksdorp
Could somebody help me, we have two CitectHMI/SCADA I/O Server Redundancy network in our plant. Recently I've added a new CitectHMI/SCADA Display client in the network. I've run the Computer Setup Wizard exactly the same as other CitectHMI/SCADA Display clients. But everytime when the primary I/O server goes down (OFF) I loose communication to the specific new display clients. Other clients are running ok as they look at the standby I/O server.
Maybe I am missing something on a setup, please help!
Compare the citect.ini file locate normally in c:\windows\citect.ini
from the display client that is woking to the other one. Specifically the [lan] and [dns] parameters.
We are trying to set up a newer generation Omron PLC (NX/NS Series) with Citect / Aveva Plant SCADA using the Ethernet/IP CIP Protocol to read...
366
I have my HMI PC running on vijeo citect. Now I have connected an ethernet switch which is connected to the PLC. To access the plc using OPC...
1,177
I have built a simulator using a micrologix 1000 and various equipment that replicates a process and hope to later use this to train apprentices...
1,560
<Citect> Computer Setup Editor - Search parameter reference returns nothing, why? As above. Anyone can help?
1,588
Hi all. I am hoping to setup a very cheap citect computer for a customer. Im currently looking at slotting a PKTX card into a PC to communicate...
1,788
