How to start up a RSVIEW project ?
sHAWN YI
Guest
S
Hi all masters:
Right now I can creat a sample RSview project now. But each time I start up the project, I need to click "RSview Runtime", then open the project. Could you please tell me how I can set up the project so that when I start it, it can go the the main page directly itself?
Thanks a lot.
Shawn
Shawn,
I think you should register on this great forum and become a member and not just a Guest.
Now for my $.02 on your question......On my RSView Projects we don't start and stop them on a regular basis so we don't run into your issue or concern.
You can set the initial graphic at start-up by going into the system folder in the project manager and selecting start-up. In here you control how the program works at start-up
Bob O.
Hello Shawn
Starting RSView32 Runtime automatically
To automatically start RSView32 Runtime each time Windows starts,
include an RSView32 Runtime shortcut in the Windows Startup
folder. You can also open a project when Windows starts.
To add RSView32 Runtime to the Startup folder:
1. Click the Windows Start button, point to Settings, and then click
Taskbar.
2. In the Taskbar Properties dialog box, click the Start Menu
Programs tab.
3. Click Add. The Create Shortcut dialog box opens.
4. In the Command Line field, do one of the following:
to open RSView32 Runtime when Windows starts, specify the
path to RSView32 Runtime. If you choose the default
installation, the path is: “C:\Program Files\Rockwell Software\RSView\Rsvrt32.exe”
to open RSView32 Runtime and open a project when Windows
starts, specify the path to RSView32 Runtime and to the
project. Add the /r (run) parameter to the command line. If you
choose the default installation, the path is:
“C:\Proj 1\Proj 1.rsv” /r
where Proj 1 is the name of the project.
If the path contains spaces, you must enclose it in double
quotes. The /r parameter must be outside the quotes.
5. Click Next.
6. In the Select Program Folder dialog box, select the StartUp folder
and specify a name for the shortcut (for example, RSView32 Runtime).
7. Click Finish.
Best Regards
Jesper
beerchug
Thanks & micros
Dear All,
Thanks for your replies. It's really helpful to me. In fact I am a member in this great forum. Sometimes I log in, but sometimes not.
I can't find the micro commands list in RSview Help file. Could you please tell me where I can see it? Is this all comaptible with VB instruction or not?
Thanks again.
Shawn
Hej Shawn
As fare as I now, macro´s in RSview has nothing to do with VB/VBA.
You find macro´s under the folder "Logic and Control" in the "Project Manager".
For the Commands try:
Help -> Contents: Type in "Commands"
Best Regards
Jesper
beerchug
Can someone help me in RsView 32? I am not a student. I am trying to just program a simple start-stop in RsView 32. When I used Archie Jacobs...
3,277
I am having a little problem with the AppStart command in RSview32. My application opens an Excel spreadsheet using the command Appstart Excel...
7,294
179
How to fix if appears code “$115 plc-restart running” on the screen OP17
248
Hello everyone, I'm new here. First of all I just want to say that you guys are very knowledgeable and reading your posts on here has saved my...
170
