how to stop controllogix minor error log
wilsonzhu
Jan 2008
vancouver
278
I have a porject using controllogix L62, There is some minor error which is cause by assign big integer to INT data type, But it's communicate to modbus device and PLC5, it cann't use DINT, do we has a way to inhibit these minor error showing up in the controller properies Minor error tab. Thanks,
alternate solution
use COP MyDINT MyINT[0] 2
then mov Myint[0] NetworkAddress
MyINT[0] has the lower 16 bits of the DINT
MyINT[1] has the upper 16 bits of the DINT
you now are moving a INT to an INT so no overflow occurs
I've purchased a Cattron Safe-E-Stop for use with a conveyor system. I've figured out all the configuration and wiring except for the ethernet/ip...
2,359
We have a MODBUS communication with a flow meter micro motion (Emerson), the communication is working, but sometimes stop the communicate. To...
2,421
Hi need help why this “failure 5 emergency stop “ appears at every startup in the morning ? Have to shut off main switch at least 10 times on...
19
313
I'm looking to get some spare keys for this PLC. Does anyone know a source or have a part number? My searches are turning up nothing at the moment.
81
Hey all, I am currently working on a depalletizer for a customer and we are doing a hoist upgrade. This is a SLC500 processor and the drives are...
307
