(1761-NET-AIC) communication Stop Controllogix
invitti
Feb 2009
Serra
We have a MODBUS communication with a flow meter micro motion (Emerson), the communication is working, but sometimes stop the communicate. To return to communicate I change the parameter "Mod_CommdMax" to 0 and then return to 40 and normalizes. I am using the serial port, in controllogix and interface 1761-NET-AIC.
Could someone give a hint about this problem.
More information:
PLC: Controllogix ,
Software: RSLogix version 13;
Serial port configuration: 19.2k
Serial adapter: Rs232 to Rs485 1761-NET-AIC
Hello, currently I have a micrologix 1200 (1762-L40AWAR )connected to an HMI panelview 600(2711-T6C3L1X) via the 1761-net-aic module, I want to...
1,789
I've attached pics, below. I'm in the field right now an am trying to communicate to the Micrologix 1500 through the 1761-NET-AIC (Ugh!) to...
1,947
The manual for the 1761-NET-AIC shows connecting a PC to DH485 network with a 1761-PM-02 cable. Is this done using a DF1 driver set to...
1,063
A customer of mine has a ML 1500 LRP connected to a Net-AIC+ via the mini din connector (CH 0 of plc to port 2 of AIC) from this AIC then connects...
1,784
I have a bunch of ML1000 PLCs on a DH485 network using 1761-NET-AIC modules and we are replacing the ML1000s with ML1400s. Once all of the...
2,000
