Micrologix 1500 to 1761-NET-AIC, In the field right now... help?
AutomationTechBrian
Jul 2013
St. Cloud, MN
669
I've attached pics, below. I'm in the field right now an am trying to communicate to the Micrologix 1500 through the 1761-NET-AIC (Ugh!) to troubleshoot the machine and figure out why it is ignoring a command.
Bottom line.... how would you do this? I have a Windows 10 laptop with XP and Windows 7 VMs. RSLogix 500 is currently on the host (W10). Just to check, I tried connecting the USB-1747-CP3 to the AIC and auto-configure Linx in the RF232 DF1 driver. No luck. Now I'm scanning the internet to see what I have to do to communicate.
I see Ken Roach warning I'll never connect with a W7 OS... a long time ago. So... what if I install an earlier version on an XP VM? Is there a converter that would work? What is the current path to communicate?
I'll keep browsing for answers, but I'll be watching my mail for post notifications. Thanks!
Anything plugged into the port on the left of the processor? the LSP has one COMM port the LRP (yours) has two ports, there is a DB9 on the left next to the Panduit, maybe a tight fit but try plugging your CP3 into the DB9 on the left side and try the DF1 using auto config
Ya know... I didn't need to read anything. I grabbed the CP3 and plugged it in... DF1, Auto-config... BINGO!
I'm in! Program is uploaded... without comments, of course. But I have a drawing with the I/O, and hopefully I can follow things back from the outputs.
Thanks (again)!!!
A customer of mine has a ML 1500 LRP connected to a Net-AIC+ via the mini din connector (CH 0 of plc to port 2 of AIC) from this AIC then connects...
1,785
I have searched for hours trying to find an answer in the threads some seem to come close to my issue but not exact. I am trying to communicate...
17
8,060
Hi all, I have need to communicate 1500 and 1200 plc's through wireless modems. The modems are of prosoft radiolinx RLXIB-IHW. The topology is as...
1,562
Need help setting up the MicroLogix 1500 to send emails.Also need to know how store a string in a data file.
2,272
91
