Micrologix 1500 LRP to 1761-Net-Eni
This is what I have so far. From what I can tell Linx is only
"seeing" the Net-ENI and not the Micologix 1500 LRP.
I have the same Ethernet Driver AB_ETHIP-2 configured for logix 500, looks like logix can also see the Net-ENI as shown by when I click on the communications tab and select the driver, but I do not have the Micrologix.
Not sure if this is relative but I have also noticed my laptop "work station" is not a "found node" in any of the drivers. I am able to ping the Net-ENI WITH 0 packets lost.
Got it to go online over Ethernet and force on some bits and it worked, all i had to do was in the communications window in Logix highlight the Net-ENI and click the online button, I was sure it would have shown the Micrologix attached but I guess not, thanks for all the info and advice Ken.
Does anyone have an example program using control techniques EN drives?RSLogix 500 ver 6.3, to be put in the upload section on here. I’m wanting...
1,358
Hello everybody I am new. hope get some help on here. I have a micrologix 1500 Lrp and a marking device. I would like to use Ethernet to...
1,374
I can't believe I would need assistance on this issue, didn't think this would be a problem. Anyways, I just bought a Micrologix 1500 LRP plc in...
7,176
Hi, Need to communicate Allen Bradley Micrologix 1764 LRP with my Laptop to read data (coil & holding registers) via modbus rtu protocol using...
5,406
I am trying to set up a MSG read in a Micrologix 1500 LRP series C to read data from a Compactlogix L32E via a NET ENI series D. I have...
8,525
