Modbus RTU with MicroLogix 1500 lrp
Caveman
May 2002
Cadiz, Kentucky
212
Does anyone have an example program using control techniques EN drives?RSLogix 500 ver 6.3, to be put in the upload section on here.
I’m wanting to build a sawmill because I have most of the stuff needed.
I found one that uses an ABB drive. I’m not able to open it, I guess because it used a current version.
There will be three drives used and an old panelview.
I have over 100 acres mostly wooded and its ready for harvesting.
Could be a good retirement income, especially since lumber prices are thru the roof.
So...do you have any programming experience?
I would think the saw speed would be constant, but maybe the feed rate would change as needed. How are you doing thickness control? Encoder? or Manual adjustment?
I have visited a restored unit that ran off a steam engine, everything was single speed with manual adjustments. A straight feed system is key, no one wants tapered lumber.
Programming experience yes.
Thickness control will be EN drive with FM2 module. With ball screw and linear bearings. Horizontal cut.
X axis will be Parallel, drive shaft connected, Parker belt driven linear actuators.
I have a spare Micrologix 1400 Series B I bought used on Ebay awhile back. I had thought of it as a spare PLC for my train project but I screwed...
1,260
I been tasked with setting up communication between a heating cooling unit manufactured by Advantage Engineering and a Microloagix 1400 plc. The...
2,517
Hey everyone, Ran into a bit of an issue with a Modbus RTU radio link on a MicroLogix 1100. Just for context, we have a remote lift station with...
31
13,555
we use M580 which have an Modbus RTU port correct if iam wrong now should i have to read input data from ab micrologix through read var block and...
1,861
I am just getting information about a need that a site has. They currently have a machine that has a ML1200 and is being interfaced to by a...
6,670
