How to tell how much memory is used with RSL 500
Bullzi
Jun 2012
Colorado
1,530
Hi Everyone,
Working on a program for a ML1400 B but don't have the processor with me.
Is there a way to tell how much memory is used and left offline in RSLogix 500? I know it can be done in 5000 but haven't found it in 500.
Thanks!!
have you tried looking at the "Controller Properties" feature - on the "General" tab? ...
if "Memory Used" and "Memory Left" show up as * (asterisks) try doing a "Verify Project" step from the very top RSLogix500 menu ...
DISCLAIMER: I'm going by memory here - so this might not be right ...
That worked Ron!!
I was getting the * but didnt do the Verify Project.
Thanks again, YOU THE MAN :)
Bullzi said:
...I was getting the * but didnt do the Verify Project...
Yes, just be careful when you see the asterisks (*) as this means there are pending rung edits somewhere in the project. If you Verify Project then you may inadvertently apply edits you had not intended to leave or had not yet finished.
Another method I use for a quick synopsis of a project is the File > Summary Info...
It will give you a couple of tabs with the Statistics tab being of the greatest interest. Here you can not only view the Memory Left and Memory Used but also things like Revision number and Total Editing Time for the project, among other useful tidbits.
Note: The Summary Info will also display asterisks (*) when there are pending edits.
Regards,
George
Hi all, I need some local help to upload the Crimson program from a G310 Red Lion HMI. It cannot be easier than that. The thing is (for reasons...
1,060
Hello: Working on a program that needs to read some data from other Rockwell PLCs. Every second my program sends "CIP Data Table Read" command and...
30
6,958
I found these two software dongles in an old desk occupied by one of our automation guys. The black one looks like an Indusoft dongle but it...
3,744
Hello Everyone. I know with Rockwell stuff, the series card is important, cant' just swap a series A input card with a serB, even if the catalog...
1,905
You can always tell when a hurricane is brewing.... the skies in the south are blue, I do miss the blue skies of the west coast, in the south once...
1,723
