How to tell if a Motor is really running?
If you want to get really fancy, depending on what kind of PLC you have, you can use an fancy electronic overload such as AB's E3 overloads to receive lots of different information about the load.
Hi Everyone,
This is a situation where I need the fan to be running for the equipment to operate safely. So I am looking for ideas on how to know the motor is running other than using the AUX contact. I was thinking of using a current switch on the wires to the motor. Anyone have experience with those?
I have used Cutler-Hammer sensors for this purpose. For example, from Allied Electronics:
ECSJ Series Current Switch CurrentWatch Current Sensors
As others have implied, a process hazard analysis or safety risk assessment will help determine the level of confidence needed by this sensing application. With sufficiently low risk, one of the digital switch models is very cost effective. Depending on the motor and other considerations you may want them on two or three phases, and/or analog output versions at added cost.
I've also used clamp-on CTs with 4-20ma outputs to ma inputs on either DCS or PLCs in the past with great success. They are also pretty inexpensive, under $50 a piece if i remember correctly.
We use air proving switches, air flow sensors, CTs, and shaft non-contact tachs depending on the importance of the application.
sir plz tell me how to interface servo motor with abb micrologoc 1400b plc plz give me detail of instruction and wht type driver may i use or tell...
2,508
Hi all, I need some local help to upload the Crimson program from a G310 Red Lion HMI. It cannot be easier than that. The thing is (for reasons...
1,060
Hello: Working on a program that needs to read some data from other Rockwell PLCs. Every second my program sends "CIP Data Table Read" command and...
30
6,975
I found these two software dongles in an old desk occupied by one of our automation guys. The black one looks like an Indusoft dongle but it...
3,746
Hello Everyone. I know with Rockwell stuff, the series card is important, cant' just swap a series A input card with a serB, even if the catalog...
1,907
