How to use Logix 5000 SRT instruction
Samneggs
Apr 2003
SoCal
37
I'm trying to pick the highest of 4 values using the SRT instruction. The attached ladder works but seems somewhat cludgy. The done bit toggles every scan and initiates a sort. The sort array switches between the original values and the sorted values. (back and forth) I'd rather use the SRT instruction than other code since the number of values may rise substantially. The question - is this the correct useage of SRT?
Sam
Hi folks, in the alarm manager of Rslogix 5000, the tag-based alarm has been created. But when I tried to change the condition, it was found the...
157
I am completely stuck on building a ladder program that requires a start button to be pressed 3 times to turn on motor 1. Then motor 2 starts...
20
582
Is there a way to use the FAL instruction to do +=2 instead of +=1? I have an array that is organized with alternating "data" and "flag" values...
126
I have an AOI with revision notes. Someone entered the last note into the description instead of the notes. I cannot just click into the revision...
152
