how to use the MSG instruction and set parameter
Ken Roach
Apr 2002
Seattle, WA
17,480
I received a PM from Forum member @zhoudq and am creating this public thread for his question:
I wonder to use a MSG instruction pull the 1756-CN2R data, but i can't set the MSG parameters, because i don't understand the MSG parameter meaining, example:service code, class ,instance, attribute etc.
In addition, I get the data form the module EDS, the Listen Only - Rack Optimized path is 20 A7 24 01 2C 03 2C 01, but i don't understand the meaning, please guide me or give me the user manual of the parameter. thank you!
My first comment is a request for clarification and purpose: do you want to read parameters or objects from the 1756-CN2R itself like channel status or ControlNet statistics, or do you want to read actual data from I/O modules that are connected via that network bridge module ?
In general, when you need I/O data you get it via I/O connections that are created via the I/O scheduling and module creation methods in Studio 5000. You don't write CIP generic object reads just to get I/O values.
Please provide as much detail and context as you can.
Hi all, I'm working with a bunch of 842E-M encoders. None of them are doing anything especially high speed/high accuracy, they're just helping me...
4,007
Hi again! I have a MSG instruction in al Clx which doesn´t want to do a CIP write into another Clx. I´m sending an INT value. How may I reset the...
4,566
97
Hello all, I am currently trying to establish a message instruction to pass data from a 1756-L73 to a 1756-L71. My communication path from the...
361
Hello Friends I am trying to connect to a Zebra printer. I can print the label with hyperterminal both by RS232 and TCP/IP. Now, I am trying to...
279
