HSC on AB MicroLogix 1400
Oct 2017
Ohio
18
Is it possible to add a HSC onto a MicroLogix 1400 processor?
I am using RSLogix500 and the toolbar has the HSC button greyed out.
Is there any other way to add in the HSC?
Thank you
Agreed; the HSC instruction is grayed out because it is specific to other models of controller, like the MicroLogix 1000. I think the other high-speed counter configuration instructions like HSL, RAC, HSE, and HSD are also unavailable on the 1100/1400.
The MicroLogix 1100 and 1400 controllers have a newer operating system, and one of the differences is that the high speed counters are configured using special "Function Files", rather than specific configuration instructions.
There are also numerous RA Knowledgebase articles about the high-speed counter feature on the modern MicroLogix, if you don't want to download PDF files from (ahem !) Russian servers.
Hi, everyone I’m working on a registration project where I’m counting encoder pulses between registration marks. I’m expecting to see around 1800...
447
I am trying to program a Micrologix 1400 to control a beer keg filler using an IFM SM6001 flow meter. The meter will be set up for a pulse...
1,854
Is it possible to set up the HSC in the 1766-L32BXB as a ring counter. So it will roll over to 0 counting up and continue to count up that...
1,105
Hi everyone first of all. This is first question in the forum. I am using HSC application. I'm reading A and B pulse count. 1 round of the motor...
4,390
I am testing a program using a 1766-L32BXB I have a single ended Encoder attached to I:0/0 with a HSC:0 set up. the Encoder is on a 6" Diameter...
2,371
