HSIO configuration w/no physical wiring
Pumba
Nov 2017
OHIO
24
Found a program with some HSIO configuration using V memory setup. The problem is that there is no physical wiring coming from the inputs being referenced in the setup instructions. Is it necessary to have the setup instructions? The instructions are leading to a HSC. The V memory location is referencing that the count-up pulse is used as X0. But, after a examination of the wiring, there is nothing going to X0. Same situation with the reset V memory (X1): there is no wiring. I am using a DL6 program. And the machine is running fine. I am just wondering if the HSC is actually doing anything at all, and if not, is it even necessary to have it.
Thank you
It may have been used in an earlier version of the program. But note that the high nibble of the word sent to V7633 contain bits which control the monitoring of the battery and the power-up mode. See page E6 of the DL-06 manual.
Hi All, I've also posted this at the AutomationDirect forum. I'm casting for as wide an audience as possible. I am attempting to operate a...
2,500
Hi buds, I am wandering if you know of a way to look at the current Pulse Rate while doing a Trapesoid move for a Stepper using DL05. The...
1,530
Hi i using Kinetik 300 2097 driver control by EIP with using move absolute and incremental for motion , but i want to add same driver and motor as...
46
Hello I have a sensor that I read data with IO-LINK but I don't know how to get my data. I see that I have two modes : Process data Map0 and Map...
59
Kindly, we have the following configuration fault on a Kinetix 5700 axis. It only appears when we go online on the Plc. We are just starting the...
97
