Huge apa files from Factorytalk Studio
TerryR
Jun 2008
Michigan
Hi all,
We have a new cell in operation and it's using a panelview plus 1000. We recieved the backup files for the PLC and HMI.
We made several edits to the screens, added screens and tags with no problem. Then saved apa files were a bit over 1meg in size. As I made edits, I would email a copy to the company that set up the system. Now all of a sudden the apa files are over 23meg.
Don't see how this could be so large. The mer files are still the same size as before, and all runs ok. But what could cause the apa file to be so large? I've looked a bit at Rockwell KBase. No luck there! Anyone have any ideas?
Terry
No Pics, Strange results...
The only addition was a couple screens with simple tag data.
Something deeper I think. Before the program started saving the large apa files, all the library icons were shown, but clicking to open one shows an empty screen. Strange!! The next time the program was started, nothing was listed in the library.
It's odd that the mer file is the same size as before, and each time I recreate it.
Thanks for the reply.
Terry
Data log can take a lot of space too and they are compress in the apa
delete (or Backup) those file before making the apa save a lot of space
I needed dig deeper...
Well I guess you guys saw the cause. In an early version I added a graphic pic file for a cable, then realized I needed to reduce the size. I removed the graphic from my project tree, but did not expect it to be added in the buried project file folder. I went into the folder and removed the 20meg graphic from the folder in the project location. I had assumed when I said delete, that it would be.
Shame on me for expecting, well a deletion from the project file.
Thanks again for the feedback.
Terry
Remove vs. Delete. Remove it from the project will keep the file whereas "Delete" removes from the project and deletes the file.
As you have already discovered.
OG
Hi Folks, After many, many hours of setup/testing/tuning/etc I'm happy to announce our brand new shiny PLC forum is coming out of beta and...
30
2,151
I have a Beckhoff PLC with many AI modules. Most devices are loop powered using the same +24 VDC power as the Beckhoff Bus Coupler and all is...
674
The plc model im using is CP2E-N Using a CP2W-CIFD02 to program Omron Multi-power controller. With RS 485. Since im a beginner in PLC, i just...
1,366
I have a .ACD written for a ControlLogix L71 w/ firmware 29 with many structured text AOIs and subroutines. I need to have these converted to...
1,601
Dear all, I'm not familiar with Allen Bradley PLC, so can someone suggest a suitable AB PLC or PAC that can afford the following I/O: Digital...
4,173
