The plc model im using is CP2E-N
Using a CP2W-CIFD02 to program Omron Multi-power controller. With RS 485.
Since im a beginner in PLC, i just started to learned about RS 485, read the whole omron multi power controller but have no clue on how to program it in cx programmer, 2 days ago while i was testing some programs the COMM (EX) was light up which i assume it has make communication with the controller but now it has turn off again and the error A50.04 is 1. A638.01 does not light up from the function block or if i use MOV commands to program.
Can anyone explain to me why does the A638.01 will not turn on and A50.04 does turn off after i reconnect the supply but turns on again after i turn A638.00 on again. And how do i program the controller if it only shows CompoWay/F and no other way like function codes or the sort.
Edit: The Multi-power controller is OMRON G3ZA-4H03-FLK
