The original article can be found on The Internet Archive,
https://web.archive.org/web/20040918074926/http://joseph-bartlo.net/articles/070297.htm
Paraphrased here:
During a wet-bulb process, air and water vapor coexist. Some of the vapor is condensed, or water vapor is evaporated in air, saturating it. During these isobaric processes, water vapor content changes, and air volume adjusts accordingly. Vaporization latent heat is responsible for all temperature change (no ice crystals assumed). The governing equation for this process is :
(Md Cpd + Mv Cpv) dT = - Lv dMv [1]
Md : dry air mass
Mv : water vapor mass
Cpd : dry air specific heat, constant pressure
Cpv : water vapor specific heat, constant pressure
Lv : vaporization latent heat
T : temperature
R : water vapor mixing ratio
Rw : saturation mixing ratio for Tw
Calculating dew point and relative humidity using (1) involves the following procedures:
1. Calculate Lv using Tw & [7]
Lv = 2500800 - 2370 T~
2. Calculate Rw using [8] & [10] with Tw & Ew
(= Es with T = Tw)
Es = 6.112 e(17.67 T/(243.5 + T))
R = z E / (P - E)
3. Calculate R~ using [6] (use R~ = Rw/2 initially)
R~ = (R + Rw)/2 T~ = (T + Tw)/2
4. Estimate R using [5]
R = Rw + ((Cpd + R~ Cpv)/Lv)(Tw - T)
5. Repeat 3 & 4 until R converges (should only require 2 or 3 iterations)
6. Calculate E using [11]:
E = R * P / (z + R)
7. Calculate Td using [9]
X = ln(Es/6.112) [9a]
T = 243.5 X/(17.67 - X) [9b]
8. Calculate H using [12]:
H = E / Es
________________________________________
Example : Suppose T = 25.0 °C (77.0 °F), Tw = 16.0 °C (60.8 °F), and P = 1000.0 mb
1) Lv = 2500800 - 2370(16.0) = 2462880
(last 2 digits insignificant)
2) Ew = 6.112 e(17.67 (16.0)/(243.5 + 16.0)) = 18.169
Rw = (.62197)(18.169)/(1000.0 - 18.169) = .011510
3) R~ = .011510/2 = .005755
4) R = .011510 + ((1006.3 + (.005755)(1850))/2462880)
(16.0 - 25.0) = .007794
5) R~ = (.007794 + .011510)/2 = .009652
R = .007767
R~ = .009639
R = .007768
R~ = .009639
R = .007768 (converged)
6) E = (.007768)(1000.0)/(.62197 + .007768) = 12.335
7) X = ln(12.335/6.112) = .70215
Td = (243.5)(.70215)/(17.67 - .70215) = 10.076
8) Es = 6.112 e(17.67 (25.0)/(243.5 + 25.0)) = 31.674
H = E / Es = 12.335/31.674 = .38942
(Credit Joseph Bartlo)
