Very high temperature humidity instrument?
g.mccormick
Jul 2012
IN
961
Does anyone know of a sensor/transmitter that is able measure humidity/dewpoint/water concentration in a stream of 1200F air?
with a mirrormeter you can detect the dewpoint as it has only a cooler and a tempsensor.
the old method with a wet sock around a temperature sensor and a normal sensor is also working at any temperature.
I freely admit I don't have personal experience with this, but at 1200F, that'd have to be a REALLY wet sock, wouldn't it? I'd think almost anything would just burst into flames, with the water instantly flashing to steam.
yes that is the way these sensor works, it is evaporating all the time, however this needs energy, so the sensor will be colder as the dry one.
and yes the water is boiling, but insulation of the container can be done.
I'm experience issues on a linear pick and place machine. The drive is a AXIMON DV10 and the Controller is an AXIDYNE 9972443. The problem I'm...
1,860
Hello everyone! So, i have this display that shows filler speed, the display receives a 24VDC signal from a Flex I/O. The speed is calculated by...
4,603
I've come across a new issue that has me stumped. We have a lumber sorting system that keeps timing using a 1771-VHSC and a 1000 pulse encoder...
5,357
Hi. I have a 222 CPU. I need to recover the program from the eeprom memory. Is it possible?
92
I noticed in Rockwell AOIs, they add a BOOL Output parameter at the end of the "Parameters" list of each AOI that carries the same name as the...
81
