RIO 1794-ASB Very high Retries counter
slick_2323
Mar 2020
MO
I'm experience issues on a linear pick and place machine. The drive is a AXIMON DV10 and the Controller is an AXIDYNE 9972443. The problem I'm having is the shuttle is not returning to an accurate home position. The control uses discrete inputs from a RIO 3/4 rack. The DV10 drive, motor, encoder, and gear box have been swapped with the mirrored outfeed side and the problem still persists at the infeed side.
While looking at Channel Status I noticed a very high Retries counter for Rack 4(Infeed side) and Rack 5 (outfeed side). What causes a Retry counter to increment?
Notes:
PLC5/30
1794-ASB
230.4 kBaud
Rack 7 is not in use.
Screenshot 2020-10-19 152546.png Screenshot 2020-10-21 071528.png Screenshot 2020-10-21 071637.png
Past experience with RIO suggests either a cable fault, or termination fault.
Sometimes even a strand of wire overlapping to the other terminal is enough to cause an issue.
Check your cable core terminations carefully, is what I would do first.
Maybe check the cable run, if you can, to see if there are any places with potential damage.
Retries are definitely usually caused by a damaged cable. RIO and DH+ will frequently run on just a few strands of corroded copper and missing termination resistors, but retries are the most common evidence of damaged wiring.
But I would expect a damaged cable to cause retries on the other adapters as well; it's a daisy-chained network after all.
So I would also check the power supplies to those adapters, and their grounding, and any sources of noise, or substitute a known-good 1794-ASB.
Start by cleaning and re-terminating the cable, and checking for any bends or crimps or crushed sections.
The RIO terminations looked decent, do they make a dual plug for the 1794-ASB to better daisy chain the modules?
The thing I found that helped the most was the RIO was ran next to a 480V motor on a freq drive. When I moved the RIO to the other side of the cable tray the retires where almost reduced by 90%.
Thanks for the tips!
Try to run your RIO cable inside a metal pipe in the places where it crosses power cables, it will help a lot.
Hello all. I have a job to add a 1794-IE8 Card in slot 5 on an existing Flex IO Rack which uses a 1794-ASB communications module, which...
2,997
Sorry to bother everyone but I'm having real problems. The setup is: SLC5/03 with a 1747-ASB series B in slot 1. 1794-ASB series E in the field...
2,147
hi i try to setup 6 1794-asb to a 1756-dhrio channel B. do anyone know how to adjust the dipswitch of the 1794-asb module ?. i already look at the...
2,868
Greetings all first wanted to say thanks for all the great info as I have been looking here a lot trying to figure out my issue, but having said...
4,767
Hello, I am currently using a Control Logix with RSLogix 5000 trying to communicate with my 1794-ASB(Has a power supply, adapter, 16 point input...
6,043
