Humidity measurement
Marcell
Nov 2003
Benoni
17
I'm in the process of building a incubator(PLC Controlled- what did you think). Might even hook a scada up to trend the temperature and humidity. Is there a cheap way of measuring the humidity?
We've had a number of design discussions and done some extensive testing on enclosure heating/cooling solutions for various panel builds...
696
Hi, I am using a DL-06 form directlogic. I need to measure humidity with this PLC. I was wondering if anyone could direct me to a good supplier...
3,581
I am looking for temperature/humidity sensor recommendations. Would like the sensor to display temp and humidity. Need to connect to a Contrologix...
236
For you instrument people. I'm using a PLC, VFD, and HMI for climate monitoring and control. Automation direct has combo Humidity and Temp sensor...
2,027
Does anyone know of a sensor/transmitter that is able measure humidity/dewpoint/water concentration in a stream of 1200F air?
3,436
