Hydraulic jack troubleshooting
blackbird307
Jun 2015
Winnipeg
59
Hey all!
I don't know a lot about hydraulic systems other than some basic fluid mechanics. I have an engine crane, with a hydraulic cylinder. I don't know how hydraulic cylinders work.
As of recently my engine crane/hoist/cherry picker, whatever you call it doesn't lift anymore. I noticed over time it had less lift with each pump I gave it. I didn't see any oils leaking out, so I guess I can eliminate that.
What is causing this? Do I have air in the system and need to bleed it out? How would I do this?
Or maybe the cylinder is just bad, are they easy to replace? I am kind of short on cash and really don't want to buy another entire cherry picker.
Thanks!
If there is air in the lift cylinder it will be spongy. Jack it up so it lifts a few inches and then press on the end of the boom. If it feels springy you may have air in the lift cylinder.
My guess is the pump piston seals are shot.
As for repair, I don't know that you will be able to replace the parts for less than a new hoist will cost you. You may be able to tear it down and rebuild it but I've never done that.
Keith
Is it still lifting, but not as much? If that's the case, you could try bleeding it.
But I would check the relief valve to make sure that it isn't dumping directly to the tank.
Yeah it lifts very slowly, then at a certain height it stopped lifting.
Now it doesn't move at all. Ill try bleeding it, anyone know who I would do this?
It's like this, only not this specific brand
http://www.princessauto.com/en/detail/powerfist-2-ton-quick-lift-folding-shop-crane/A-p8210072e
There is a valve or something that I turn when I want to lower it.
It's frigid cold out, but I am in desperate need to fix my truck and swap the engine. Which would probably explain why it's not working too well. I know hydraulics don't work to well during cold temperatures, I have been getting past this by heating up the cylinder with a heater.
I appreciate all the replies.
To bleed air out I used to crack a fitting open and exercise the system. Did that on cherry pickers back in the day. It also spilled a lot of oil, so I'm not sure my method would be allowed today.
In most systems just exercising it will get the air out unless there is a pinhole leak pulling air in somewhere.
Stupid question: hav you verified proper oil level in the reservoir?
It sounds like you are low on oil if it stops lifting at a certain point. On the side of the jack body there will be little rubber plug painted the same color as the body. Pull it out and pour in some hydraulic oil.
I am thinking about changing a previous design from hydraulic cylinder into screw jack. I want to replace a 1000 ton hyd cylinder with 10 screw...
2,803
Hello everyone, I'm reaching out for assistance regarding a project I'm currently working on. Specifically, it involves a hydraulic system with...
425
Hi All, I could do with some advice on a hydraulic control system. It is necessary for me to accurately position a vertical hydraulic ram with...
34
1,979
Hi, I am about to start a project controlling a hydraulic ram using a Siemens S7-1200 controller. It will need to be quite steady control, by...
769
Good Evening Everyone, I am attempting to monitor the level of hydraulic fluid in a tank. The tank is 50 gallons. For insurance purposes we need...
16
4,209
