Hydraulic oil Temperature Sensing
gbradley
Apr 2002
Corona, Ca.
1,637
I'm rebuilding an old press with some new hydraulics.
Most of it is done, but I want to add a thermostat for the oil.
Actually since I already have the SLC 5/01 & PV600, I would like to have the actual temperature Displayed on the HMI.
Do I need to buy the 1746 NT4 Thermocuple input?
Can I get a thermocouple with a 4-20 mA output and connect it into the 1746-NI4 Analog input card that is already there instead?
Another suggestion is to use an RTD instead of a thermocouple. Perfectly adequate for the temperature ranges you are looking at, and they are less prone to noise and don't require special wire or terminal blocks. Here is the signal conditioner for them:
http://web3.automationdirect.com/adc/Shopping/Catalog/Process_Controls/Signal_Conditioners/FC-R1
Another possibilty is a device from Dill Instruments I've used for this service many times. They even have an RTD with a built in 4-20 mA transmitter.
http://www.dillinstruments.com/4-20.html
I forgot the rule I usually follow around here. Make sure the maintenance person who assembled the hydraulic lines and connections is the one...
2,551
Dear All, It is a bit irrelevant question for this forum but I've not get a satisfactory answer to my query. ""When a Oil well is bored and a...
2,926
The Plant Safety Officer wants an oil mist detector installed in an unattended hydraulic pump house to detect when a fine spray high pressure (we...
5,376
Hello everyone, I'm reaching out for assistance regarding a project I'm currently working on. Specifically, it involves a hydraulic system with...
422
Hi All, I could do with some advice on a hydraulic control system. It is necessary for me to accurately position a vertical hydraulic ram with...
34
1,966
