Oil and Gas Hydraulic Interlocks
jawad rasool
Feb 2012
Lahore
51
Dear All,
It is a bit irrelevant question for this forum but I've not get a satisfactory answer to my query.
""When a Oil well is bored and a Production tube is installed, then Methanol is injected to the annulus (Empty area between the well walls and Production tubing) to provide a Hydraulic Interlock for avoiding Oil to seep from production tube"
Why only Methanol is used???
Which parameter plays the role to select Methanol?
you are right - not on this forum
But
the idea of a barrier to both detect and prevent leakage would be the reason.
I am guessing that Methanol will not react with Crude Oil
where as other fluids may explode
Who says that only methanol is used between the outer well casing and the production tubing? From the little I know about oil wells, depending on the circumstances and pressures, other fluids are used, including various types of cement, salt water, and muds.
Packer Fluid n: a liquid, usually salt water or oil, but sometimes mud, used in a well when a packer is between the tubing and the casing. Packer fluid must be heavy enough to shut off the pressure of the formation being produced, and should not stiffen or settle out of suspension over long periods of time, and must be non-corrosive.
Methanol seems a good choice - easily made transported and handled. Fairly low freeze point so wont freeze easily in storage tanks. Water soluble so it can "extract" water from oil
If it gets into the product it burns also.
Dan Bentler
This was sent to me by Jack L Johnson, one of the other hydraulic gurus. Helmerich and Payne is one of our customers. Read below and you will...
2,364
Hi everyone, thank you for reading this post. I would like to call up for opinions in regards to oil and gas entry jobs for somebody that doesn't...
41
14,867
Hey all,, This is my first job. Completed 1 year a couple of days ago. Working in maintenance department. Even though i get to learn a lot i am...
4,062
Hello to all, is my first post on the forum, I searched everywhere, but I could not find an answer to this problem; I am quite experienced in...
999
So I'm having issues with a certain rung and one of my coworkers mentioned it may not allow the signal past the latch coil. For example in the...
27
3,763
