Hydraulic Robot With Gears
EastSidePK
Oct 2009
Port Huron, Michigan
Hello, everyone I'm new to this put from what i've seen here you guys know your stuff. I'm in college learning about Automation systems, and I have a hydraulically operated robot with gears (that have limit switches, to act as primative encoders i assume). What I am curious about is, once write the program how should i go about controlling its position? Since everytime each gear moves, it sends the false to true signal via limit switch to a PLC, should i use a squencer or shift regisiter? There are only 32 teeth on these gears, also. I've got a fair amount of programming experience in RSLogiX 5 and 500. Any suggestions would be awesome, since i am perplexed at the moment! Thanks
Don
Encoder signals are generally sent into counters. Depending on how fast the on/off transitions are happening, you may need a special input card called a high speed counter.
Another consideration is whether or not you can tell direction from the signals. If you have two pickups that have the right phase relationship, you can tell which way you are going and can do a count up or count down.
That should be enough to get you started and off on some google searches.
Good Luck
So the gear RPM and position (relative to a home position) can be obtained from limit switches counting gear teeth?
Just one switch per gear?
How fast can gears rotate? Thus how many pulses per second from the limit switch on a gear?
Dan Bentler
Does it have a zero position or a home position sw or sensor?
If so I would use a counter to increase / decrease the position according to the rotation. You have to know the direction as Norm said. Use the home or zero position to zero the position.
If you have 2 sensors and can set them up to read 90 degrees out of phase. You can get 5.625 degrees per increment if you only have 1 you will get 11.25 degrees. If you get very fancy in logix you can count the 4X
My guess is the this is a school so it will be a slower system.
Hello everyone, I'm reaching out for assistance regarding a project I'm currently working on. Specifically, it involves a hydraulic system with...
415
Hi All, I could do with some advice on a hydraulic control system. It is necessary for me to accurately position a vertical hydraulic ram with...
34
1,923
Hi, I am about to start a project controlling a hydraulic ram using a Siemens S7-1200 controller. It will need to be quite steady control, by...
763
Good Evening Everyone, I am attempting to monitor the level of hydraulic fluid in a tank. The tank is 50 gallons. For insurance purposes we need...
4,177
Hi I have an electro hydraulic valve with coil resistance 22 ohms that takes as +/-12V DC input with 40Hz dither superimposed. The valve controls...
2,527
