Hydraulic Servo in S7/Logix5000
Manglemender
Jul 2007
Lancashire
1,295
Hello Forum Members,
I'm looking into an application that requires a hydraulic axis to be servod to position with a high degree of accuracy and repeatability so a dedicated hydraulic servo controler would seem to be required.
I hear that there's a card available that plugs into the rack of a Logix5000 PLC but there doesn't appear to be a equivelent for the Siemens S7 range.
The customer wants to use a 315-2 PN/DP but may o with the Logix5000 solution.
I'm interested to hear other people's expriences / recommendations for integrating hydraulic motion into a PLC environment.
Nick
Cant tell you if AB have a card for this but you can use a TrioMotion Cantroller
to control the hydraulic and communicate from AB over Ethernet/IP to Trio.
Not the app you are looking for but a alternative that works great!
I am watching
It depends on the application requirements and what PLC is going to be used. Some hydraulic controllers are more powerful than the PLCs and can do everything themselves without the PLC as long as the I/O count isn't too big.
I have LOTS of application examples.
By now you should know that my company, Delta Computer Systems, makes hydraulic motion/force controllers that communicate over Ethernet or Profibus or fit into the PLC.
Siemens 315T and IM174 work great
Don't try the FM354 for hydraulic motion
Thanks for all the replies.
I knew that "at least one person" would recommend Delta Motion to I've had a look at the web site and the products o look very good and would certainly be appropriate to te task. I had a look at the website of the listed UK distributor but Delta Motion certainly doesn't feature prominently.
I haven't seen this machine yet but the application is a hydraulic press that, I'm guessing, will need to be controlled in speed and position and maybe a profiled move.
I have thought about using the 315T/317T but I'm trying to avoid that solution for three reasons: 1) Customer resistance 2) The software does not happily co-exist with Simotion Scout, 3) It's an odd product that I dont think is being "pushed" by Siemens.
Once again, thanks for all the replies,
Nick
Nick
T CPU can be programmed with Scout (So if you already have Scout you dont have to buy T config software)
Siemens is very much promoting T cpu. As a matter of fact, 4.2 just came out and there is an "F" failsafe version and path was added
(along with alot of added PLC Open blocks)
Your Siemens sales guy needs to get to work :)
This webinar was held yesterday. I didn't post a link to it. We had over 200 people attend it anyway. There was more question and answers on...
1,221
Since there are a lot of UK people here I thought I would ask. Has anybody taken classes at the NFPC ( national fluid power center ) in...
1,734
Hello everyone, I've been reading through the forums on motion, servos, etc. I'm looking for some help in determining the cause of some...
45
13,259
Hey Guys, Got an application where the Engineer purchased some Hydraulic Servo Valves and would like me to write a PID to control the position...
1,685
Just the other day I saw a hydraulic forming press that didn't seem to have a pressure relief valve. It had a Servo motor connected to a pump that...
2,109
