Hyper terminal
roxusa
Nov 2008
NJ
994
Trying to test a Channel 0 ASCII to Hyper Terminal using 1747-L532
Channel 0 is set to user
Do I use a Straight through cable or Null Modem from RS232 port on Channel-0
to Laptop
Test program is from a post done in RS-5 I converted to RS-500 and changed the states bits for the clock to reflect it
The SLC-5/0x serial port is DTE type, and your computer is DTE type, so you need a null-modem cable to connect them.
1747-CP3 or 1756-CP3 cables are ideal for the purpose.
HyperTerminal is OK for some purposes, but I've run into enough trouble with its handling of duplicate characters and unprintable characters that I always use RealTerm instead.
I do not use HyperTerminal either because of its issues and also because of the fact that it is not included in Windows 7 or higher. Whenever i need to use a terminal emulator, I always use puTTY. It's free, open-source, portable, has an extremely small file size, and works very well for all sorts of different terminal applications. I have not tried RealTerm, so I can't comment on how they compare.
I am looking for a replacement for hyperterminal. My XP system doesn't have hyperterminal or telnet. I am currently trying to use PuTTY but it...
19,034
I have an external device which will move the specified test data to the COM port. Can you please give me the source code which will move the data...
4,418
Just curious if anyone has any recommended solutions for gaining my USB-A to miniUSB adapter inside my VM Having an adventure with an M3401000...
1,124
Hello friends The IT department is pushing me to use Hyper-V on Windows 10. Have you use it? Is it a good option? Thanks in advance.
4,251
Anyone ever set up Archestra in a Hyper V configuration in windows 2008 R2 Need some help Thanks
1,460
