I have a problem about accessing to CP443-1 over VPN
ceyhan
Nov 2004
Turkey
Hello there
I want to communicate by SCADA to CP443-1 over VPN.
After configuring VPN (by using 2 VPN ADSL modems), computers can communicate very well between two sides. In one side, a computer (let's say computer1) which is in the same side with PLC can ping the PLC and can access to PLC by SCADA or STEP7. Another computer (and let's say computer2) which is in the opposite side of PLC can ping the other computer(computer1) and can ping PLC, but SCADA or STEP7 cannot access to PLC.
Please help me immediately. Thanks for help.
ceyhan said:
Hello there
If there is a firewall you have to pass through, I think you have to open up port '102' , this is for STEP7, no idea for the Scada maybe same problem there ..
For the past few day, I have had problems accessing the Rockwell Knowledgebase. When I try to access it (and I do have a TechConnect Support...
415
I'm setting up a PV 1000 Compact, and having a bit of a bother. After setting up the IP and netmask on the PV, same domain as the development...
2,053
Hello to all, I work as a maintenance man in one plant. We use a lot of Siemens equipment and it works good. I have very big problem and hope...
2,690
22
461
On all pages of my project i have a lot of information, texts and details that should not not be shown. I can remove them for each part apart from...
51
