Buzzen
I have a flow problem..here is the riddle. We use positive displacement pumps for chemical feeders. The flow is really low on some applications in the area of 3-4 gallons per hour, with about 5 psi. I am using a flow meter that will respond fairly accurately when the tank is full. As the tank empties the psi is around 1-2 which will throw off flowmeter. I am thinking of using a small booster pump to improve the flow hopefully improving the conditions for the flow meter. What do you think?
