I need a CQM1H-CPU51 to talk to my Red lion Da30D
pwalter
Jun 2023
Tennessee
i just need to read the status of some I/O and maybe read some data registers
but I cannot seem to get the scb41 to talk to the datastation
That's not a lot to go on but here are some pointers....
- The SCB41 is not a standard RS232C pin out. You'll need to make a cable.
- Any change to the PLC settings will require a power cycle to take affect.
- You'll use Host Link protocol.
I have already made a cable, did not know about power cycling , that should help.
if I am using host link protocol in the plc , what do i use on the red lion?
it doesn't offer host link it has Series C plc. fins master, or G9SP series
I was trying series C plc but I didn't power cycle the plc after changes.
Series C PLC is synonymous with Host Link in most cases. You'll still need to match serial parameters. I haven't used that Red Lion device so I'm not sure what they have for settings. If baud, data bits and stop bits settings are not available then I would assume default which is 9600, 7, Even, 2.
I have the baud, parity and so forth set correctly,
I am just not familiar with Omron plc's
is there a communication block I have to setup Like some of the older siemens have ?
I can access Siemens plc's and modbus units like this I just cannot get the Omron to work.
Is the data station the master.?
Can you post screen shots of your RL & CQM configs.?
Also, why the need for the SCB, is the CQ serial port used.?
I want the Data station to log cycle count data from the plc and display I/O status on the display pages.
I am using the SCB 41 to add a serial port the other port is already used in the machine.
serial port configuration is the standard 9600 1,7,2,E
lights indicate I an talking thru the serial port but the data addressing from the redlion to what is in CX programmer don't really match up
I create a data tag in the red lion and and assign it to an address in the Omron and if I look at the tag in the display pages I don't get anything
if I do this with modbus or a siemens plc I can read the status of the memory location or if it is a bit, on or off.
is there a communication setup block in Omron like the older Siemens had?
Assume CommBoardA/B ? The data station is the same?
Have you tried connecting to the same port with CX-Programmer, since the settings are the same?
How so.? Need more info to assist further.
When I have done this with the DA01D, I go to watch block & view online to get the actual data.
No, the memory in this series is fixed. Are you sure that the address exists in the CQM1?
Hi All, I'm having a problem in connecting my laptop to the Omron PLC. I have the RS232 cable from Omron but my laptop don't have the RS232 Port...
3,141
Before starting, my english is a little bit rusty i hope you guys won't mind. Anyway, I'm new to this whole PLC thingy. I borrow an OMRON...
1,652
50
I've got this 3-phase 575V motor that we're controlling with a VFD (Variable Frequency Drive), which has been quite the learning curve in itself...
282
I'm fairly new to Rockwell software, I've had some basic training in the past but nothing too advanced. My company and I use Reliable products for...
347
