I need to Translate a Siemens S7 project into Delta PLC
Prince
Jun 2002
284
I need to Translate a Siemens S7 project into Delta PLC. I am responsible for Electrical so I will not care about software.
Delta does have PLCs equivalent to S7-300 or S7-1212. I am happy with my selections. DVP12SE is more than enough. It is not a fast project and I will need Ethernet. Do you have better suggestions?
I can change PROFIBUS WITH Modbus.
But What should I do for remote IOs? (eg ET200M/S) What I see is cheap PLCs like DVP12SA to be controlled through Modbus as slaves. I know they are cheap but do I have extra options that I am missing?
Sorry for my inconvenience I am not experienced enough with Delta.
I've got this 3-phase 575V motor that we're controlling with a VFD (Variable Frequency Drive), which has been quite the learning curve in itself...
187
I'm fairly new to Rockwell software, I've had some basic training in the past but nothing too advanced. My company and I use Reliable products for...
342
169
Good day all! Can someone help me with the procedure to update Beijers E700 firmware? The Panel I am working on is firmware 2.04v and I would...
70
Good evening. I display the step number of a SFC on a display. Sometimes, on a trip, it goes quickly through many steps and I need to prove to...
133
