I/O Fault L32E
dhuggins88
Mar 2013
Russellville
32
Hello all, I have a Compactlogix L32E paired with a PV+ 1000. All my code is good and both the screen and cpu are taking the program fine. However, I keep getting the red light of death on my I/O light(on the L32E). My application goes through and loads fine but the program will not execute properly. My keyswitch on the processor is in the run mode. My question: Is there a way to get around not having all the I/O modules connected to the cpu so that I can bench test basic functionality?
One way to do it is right click on the I/O bus in the I/O tree and inhibit the bus. Or you can inhibit any missing modules individually.
We use that quite a bit for testing customers programs in our test PLC. Just gotta make sure you un-inhibit a program before sending it out to someone otherwise they scratch their head for a bit when they load it in!
dhuggins, you in Russellville AR? I spent some time there at a Tyson plant.
I am trying to address an issue with a L32E faulting the ethernet port when connected to the companies VLAN. I have a PLC network connected to a 5...
3,668
Hi All I am trying to perform bench tests on a 1769 L32E controller to confirm that the communications work with my HMI. The problem is that I do...
1,684
Hi frnds, Can anyone help me out for using the GSV instruction for 1769 L32E CPU. i have used GSV normally for CLX and it works, but in this...
5,288
I am somewhat new to PLC programming, i'm finalizing my first real program and i need to display an alarm on my SCADA for a communications fault...
3,540
Hi, I have a problem with a Compactlogix L32E, this controller goes to Major Fault sometimes, I need it clear this fault by Controller Fault...
11,389
