Logix5000 L32E PLC Fault
Tally_Pants
Jan 2010
Bedford, Nova Scotia
I am somewhat new to PLC programming, i'm finalizing my first real program and i need to display an alarm on my SCADA for a communications fault (over ethernet) to my PLC. and i'm also including a Minor / Major Fault Alarm, just curious if i'v done this effectively, as i'v never done anything like this before.
i have the S:Minor bit monitored in my controller fault handler routine, if its true then i have a minor fault alarm.
and using a GSV i'm writing to Major_Fault tag and if Major_Fault.Code NEQ 0 && Major_Fault.Type NEQ 0 then my major fault alarm goes try.
(see attached pic)
I am needing to backup a 1769-L32E and it says that I need rev 17.2 I have downloaded the firmware 17.012 How do I get it to recognize this...
1,786
Hello, everyone. New user, first post. Happy to have found this place! Spent the last few weeks learning the hard way (I'm EXTREMELY green )on a...
2,286
Hey guys. Got an L32 trying to talk to a Cardinal 205 Indicator using the Cardinal 2XX-IP interface option (as opposed to a Cardinal 2XX-EIP...
2,257
I have an L61 that I am using to poll several PLC from SLC 5/04 (DH+) to ML 1400 and Compactlogix L32E. I have successfully set up the message and...
3,331
Hi! So my problem is a little funky, I had Studio 5000 v 24 and 30 installed, but forgot to install RSLogix (which I cannot go without). Is there...
124
