Logix5000 L32E to Cardinal Scale Interface
JiNCs
Jul 2007
South Carolina, USA
66
Hey guys. Got an L32 trying to talk to a Cardinal 205 Indicator using the Cardinal 2XX-IP interface option (as opposed to a Cardinal 2XX-EIP option). Used Lantronics software to set scale IP and can ping but Linx does not see device. I noticed when adding a new ethernet module in 5000, ethernet modules exist for Mettler-Toledo scales.
Anyone got interface experience with the Cardinal 205 scales and the 2XX-IP option? Is there a special 5000 ethernet module, do I need a special EDS file?
I am getting nowhere quick!
JiNCs
Based on a quick browse of the manual, I think you're going to have approx 0 luck w/ this option card and a Controllogix.
I think you'd need something like the mvi56-gec from Prosoft to make that work.
Likely better off getting the Ethernet I/P option...
Thanks Dravik for the response and a quick one at that! I believe we used the EIP option card before and as I remember and it was 'by the book' to set up.
Thanks again!
JiNCs
I am needing to backup a 1769-L32E and it says that I need rev 17.2 I have downloaded the firmware 17.012 How do I get it to recognize this...
1,797
Hello, everyone. New user, first post. Happy to have found this place! Spent the last few weeks learning the hard way (I'm EXTREMELY green )on a...
2,296
I have an L61 that I am using to poll several PLC from SLC 5/04 (DH+) to ML 1400 and Compactlogix L32E. I have successfully set up the message and...
3,339
I am somewhat new to PLC programming, i'm finalizing my first real program and i need to display an alarm on my SCADA for a communications fault...
3,540
Hi! So my problem is a little funky, I had Studio 5000 v 24 and 30 installed, but forgot to install RSLogix (which I cannot go without). Is there...
149
