Logix5000 MSG L61 to L32E Help
kbradray
Jan 2006
Columbia
175
I have an L61 that I am using to poll several PLC from SLC 5/04 (DH+) to ML 1400 and Compactlogix L32E.
I have successfully set up the message and configured it to take information from a ML1100 and a SLC5/04 DH+.
I cannot get things set up to take information from the L32E. I have a DINT[5] in the L32E with data that I want to pull to a DINT[5] in the L61. I will be going out my ENBT card in slot 1 of the L61 at address 192.168.0.100 and the address of my L32E is 192.168.0.48.
I have been reading here, and I don’t know if it is a path issue or other configuration. I am using the CIP Data Table Read selection.
Please help.
Produced consumed tags
I am new to logix5000. I did try this with no success, so I tried to use what I knew.
I tried to create a produced tag in the L32E and a consumed tag in the L61. I could not figure out how to create the path.
If there are any examples of how to do this I would appreciate seeing them.
Hello, I have a Compact 5380 trying to communicate to a Micrologix 1400. I'm trying to access the input and output data. But when I enter O0:0 or...
748
Hello All! First Post! What is the "Timed Out" Check Box used for on the MSG instruction in Logix5000? This check box is located under the...
1,867
My question is regarding RSLogix5000"s MSG instruction. I am an automation tech. Our "Start_Command" bit turns on a motor. At one point, the...
3,901
I recently had to change the way my MSG instructions were connecting via ethernet radios; I originally had the remote PLCs in the I/O of the...
2,006
Hi Guys! I've been asked to make a simple interface to change parameters in a VFD (Danfoss), it is quite simple done using the MSG instruction...
5,122
