I want to be a good plc programmer
Buy a PLC and start programming, there are a lot of videos on YouTube and manufacturers websites
I honestly believe the best way to learn is to look at other people programs and methods of doing things. each industry will probably be alot different. I know personally swapping between manufacturing machines and process control is drastically different in the timing and instructions used.
A few good channels to learn from are Tim Willborne, Shane welcher, and Logix magazine
As far as getting your own kit and knowledge, go check out automation direct. Free programming software and cheap hardware to learn on! Enjoy my friend. Controls is like the wild west, takes a certain type of person, and is a fun ass ride!
I know the basics but i need to develop myself more
Do you know what the PLC scan cycle is? If yes, please explain here to confirm, or watch this video series to learn.
If your preferred language is Ladder Logic, then this website contains the most common patterns, which cover the vast majority of rungs programmed.
Beyond that, I agree with the sentiment expressed above: get some free software and either a cheap PLC or a PLC simulator e.g. see here.
Also, do you have any other programming experience or other skills (web developer, scientific programming, engineering or technical education, etc.)?
Another good source..
I have posted this several times. If anyone has more suggestions, please add them and pm me so i can add to the list.
For any given homework assignment or task at work, you must consider these instructions as the customers specifications.
1. read the specifications several times.
2. write down your understanding of what you read in a step by step fashion.
3. review what you wrote down and see if it makes since, modify if necessary.
4. Get with the mechanical designer and discuss the project openly and honestly. When your opinions differ in regards
to an operation, discuss it, don't ignore it.
there must be a reason for a difference of opinion. modify your instructions and i/o to accommodate the mechanical
design if possible. Mechanical design may have to be changed due to plc programming limitations.
YOU BOTH MUST be in agreement on all points of operation before going to step 5. you may have to modify/rewrite
step 2 and 3 based on the discussion.
5. step through your notes again this time, you are the one following the instructions. In other words, you are the
plc. Write down on paper the events you are doing.
For example, turn on hydraulic motor 1, write down hydraulic motor 1 on. If a sensor is needed, write that down.
6. continue through the instructions. When you turn off the motor, mark a line thru it.
7. go through your instructions with all the sensors, motor aux. contacts, outputs documented. Modify if necessary.
8. repeat step 6 until no changes are made.
9. Try to group your data words into some organized fashion. The more programs you write, the more organized you become
10. write the plc program using your notes in a step by step manner.
10A Over half way through writing the program you WILL realize a different/better way of doing something you are
almost done writing (or a new spec will require it) and you will completely rewrite it
10B It WILL happen more than once.
Note: 10A and 10B added to list. thanks Aabeck, member plctalk.net forum
11. DOCUMENT EVERYTHING!!! You may remember things today, but in 5 years and hundreds of programs later, you won't
remember, especially at 2 am, so DOCUMENT EVERYTHING. use easy to understand tags and rung comments.
12. MAINTENANCE is your best friend and your worst enemy.
if you work with them and find out what they can do, write the program where they can trouble shoot the program.
they will be able to fix the problem and everyone will be happy.
BUT
if you write the program to where you are the only one who understands what is going on, maintenance can't fix the
issue, the machine is down, production is down, management hears about it, your boss hears about it, then you hear
about it - rewrite the program or else. you get calls all hours of the day and night.
this still holds true, a machine can cost a billion dollars, but it's not worth 10 cents if maintenance cannot
trouble shoot the issue and fix the issue. everyone has their own style of programming and you must develop your
own way as well.
13. when the customer is in your shop and brings maintenance, discuss things with them, let them see your code, be open.
if they make suggestions, write them down, don't ignore them. their ideas may save you days of programming.
14. install the program and leave in program mode if possible so you can to debug your i/o
15. when writing your instruction manual(s), use your notes from step 9. Use easy to understand English language.
specify the i/o, timers, counters, outputs when possible. this will help maintenance even more to see what is going on.
16. Question for you, when is a machine and plc the most dangerous and why?
When it’s first powered on – when power is first applied to a machine, you don’t know how things are wired.
When you energize the plc outputs, you don’t know how they are wired.
When the plc is put into run mode the first time, it will do what you told it to do, NOT what you wanted it to do.
17. debug the program.
Remember, the program will always do what you told it to do, NOT what you wanted it to do.
18. IF you can ask a what if this happens type of question, YOU MUST have an answer, EVEN IF its a 1 in a million
chance. that what if situation will happen in the first 30 minutes of production runoff in front of the customer.
hope this helps,
james
Dear All, I need a sample PLC program to count the output pulse of a mass flow meter so that a specific amount of mass (for example 100gm)can be...
172
We need to get hold of someone versed in the Old Giddings and Lewis PLCs. We are primarily Rockwell Based here. None us currently in the employ...
630
I have been hung out to dry by Keyence. If I had to do it all over again, I would NOT choose Keyence. They have done nothing but lead me in the...
971
First, thank you to anyone who reads and attempts to advise and/or help me. Let me start off by giving some background. I have been a Computer...
23
7,419
Hi Friends! what salary range(on monthly base) should a beginner expect after his training as a PLC programmer with position as a 'Technical Team...
3,774
