IBHlink on WinccV7.0
clyves077
Apr 2011
Kortrijk
I use s7 IBHlink to connect serval PLC's.I use the IBHlink for MPI in Wincc.
My problem is that i have to chose between the serval plc in set pc/pg program.
Is it possible to use the serval plc at the same time?
Is a OPC server a solution?
I'm trying to develop a software which should read tags from a Simatic S7-314 / CP 345-2. For this I'm using S7.NET + c#. I'm using a IBHLink S7++...
1,552
Has anyone got any experience with Ethernet-mpi IBHlink & tia portal 14 or newer I have it working fine in simatic manager but in tia, although...
1,943
hi, i have installed the wincc into new system.when i click graphics designer page am getting the error msg.i hav attachet the error msg as...
1,541
