Ic660br101b Ge Fanuc Relay Module
Mar 2004
55
I have a GE relay module IC660BR101B mounted in a terminal base with the part number IC660TBR101A. My customer says that the TBR part number should end with the same suffix as the BR part number in order for the module to work.
What is the A (or B) represent. Is it just a series designation? So far, I have not been able to determine the suffix meaning.
thanks,
CTG
It is a version designation. I know that 'most' version B and above are compatable between bases and the modules, however there were problems with 'some' of the version A and previous units. I would try it, it should not cause any damage. Worst case is that it does not work, or you need to buy more parts.
Hello, i am using profibus as communication between plc and fanuc arm. I can easily send inputs from plc to arm, but i can't monitor any outputs...
51
I have a CNC cutting equipment, all the components are Fanuc from the CNC CPU A02B-0307-B822, a PLC AIF01A and a panel i, on the panel i (operator...
133
I want to buy this program if anyone has it. Absolutely no one has it officially for sale. My cpu is IC610CPU104B My mail...
125
I've got a Micrologix 1100 with ethernet and I'm trying to configure communications to a Fanuc R30iB controller. I'm pretty sure you have to set...
119
We recently purchased a IC693CPU352 module and it appears the internal time clock is static. I can set the time and date but once set it does not...
191
