Iconics Genesis32 V 7.1 Tag Database extraction
meghnesh
Jan 2011
Gujarat
82
I am struggling to extract the tag database from Iconics.
Its using RSLinx OPC server to communicate with Rockwell PLC's.
There is an OPC TAG BROWSER tool from Iconics. But this tool is showing all the TAGS created in the particular PLC's..
Out of all these tags how can I extract the tags which are only and only used in Iconics ??
Please help.
Please help.
Since Iconics Genesis32 is completely OPC based, you don't create tags in Genesis32, you simply use tags from the OPC Server. That means there isn't a "tag database".
The Alarm and Trend modules *do* setup tags so you *could* export AlarmWorX and TrendWorX databases to see the OPC points that are always in use, but the OPC tags in GraphWorX are only in use when they are being displayed on the screen. You could go through all of the graphics files and search for tags that may potentially be referenced (if the screen happens to be active) but I don't know of any other way to do it.
If you are trying to convert from Iconics to some other SCADA or HMI, this is probably the only solution.
Hello I am modifying a existing Mitsubishi PLC program in Genesis32 version 7. There is no record of username and password available. Is there...
1,675
hi guys i have a quick question, i have a ICD for allen bradley controllogix 5000 and im using genesis iconics32 graphworks and displaybuilder, my...
1,424
I'm looking forward Iconics. I had previously extensive experience with Citect and little bit less experience with Wonderware. Pros and cons with...
843
I am working on developing solutions using ICONICS, and I'm relatively new to SCADA in general. Whenever I get stumped on something, I end up...
1,722
Hai All, We are trying to communicate allen bradley L33-ER processor with Iconics OPC server suite 5.5.Can someone tell me what are steps we need...
952
