ideas how to do project
best49erfan
Aug 2003
Titusville FL
70
I would like to automate (cheaply) lubing the chain on my motorcycle. this would require some sort of 12VDC controller. I all ready have found solenoid and other parts, but what would you suggest as a controller?
Maybe a Red Lion Cub5 with a sensor to count sprocket (wheel) rotations and a relay output option card. You may need an interposing relay also depending on the current draw of your solenoid.
Just a thought, but if something sticks or doesn't work properly excess lube may have bad consequences!
With chains, too much lube is almost always less of a problem than too little lube. If the proper lubricant is used about the only consequences of too much is a mess to clean up. IMHO :)
This is typically true of motorcycles and industrial machinery.
Hear are a couple solutions for you.
http://www.motorcycle-superstore.co...px?SiteID=SLI|Cable Lubricator&WT.MC_ID=10010
Or you can go PLC controlled.
Part Number: IC200NDD010
Description: 10 point PLC, (6) 12VDC In, (4) 12VDC Out, 12VDC Power Supply
195.00 And you would need the software to Program But you might be able to find another Manfacture with the same 12vdc power supply. You said you had the selenoid. You just need to find a place to mount it and keep it Dry Fashion up a bracket and seems to me it could be quite an expensive Chain oiler.
I agree, but I wasn't thinking of too much oil on the chain, ;however, where the excess oil goes (ie...tires)
I had a friend who tried to make a drip oiler who had this problem, until he got the flow correct.
You will definitely want a shutoff valve in there.
Two requirements for my next bike is no chain, and likely no spoked wheels...
Best thing I ever did was Convert my 79 Superglide over to Belt drive. I did the inner primary also not cheep but well worth it.
hi! Background on me: Self learned programmer mostly on LOGO, s7-1200, regular HMIs and WinCC Flexible 2008 Runtime. Only smaller projects. The...
20
4,197
Hey everyone, I am a senior in an Electrical Engineering program. We are looking for a good project to do using PLC's. I have worked with both...
2,543
Hi all I'm designing a new student project and I want to link it to renewable energy. I am thinking a wind Generator controller , I'm no expert in...
5,844
Hello All, This is my first time here, and I'd like to get your ideas regarding a new project to upgrade an existing product line. The existing...
9,364
Project Residential lighting control Goal: to separate 3 circuits using one transformer, and use an Rf controlled system, from a remote. (to...
16
7,937
