IDEC FA-2J Programmable Controller fault
H_MUSJ
Jul 2017
Karachi
Can anyone shed some light,
All outputs are high. on FA-2J IDEC IZUMI PLC
PLC's RUN light is stable but it's not functioning the way its supposed to.
I have checked the input voltage to the plc and its fine.
The output module is used to switch on and off a number of 24VDC contactors.
There are a total of three input modules used and four output modules, but for troubleshooting purpose i have disconnected all the modules but except output module but when I'm powering up the PLC, its switching on all the outputs, same is the case with all the inputs modules connected.
Nope, i don't have the kit... Have downloaded WindLDR demo version but dont have the communication cable (trying to arrange it from somewhere), i would like to add that upon switching the PLC off then on, the output states changes randomly..
The only place I was able to find the cable was ebay. Idec doesn't offer it. There are 2 different parts to the cable. I'm not sure WindLDR will work on the FA2J. I used CLIP which runs in DOS.
Does anyone know what software the IDEC FA-2J Controller uses? And what cable is needed to communicate? I can barely find any information on this...
1,131
Apologies for not being the best IDEC programmer. I recently was doing some inspections on a site that had 3 FC6A IDEC processors. The issue is...
86
I'm trying to establish communication between an HMI DELTA (DOP-B07E515) and a PLC IDEC (FC6A-D16R1CEE) via the RS-232C/485 module (FC6A-SIF-52)...
571
Has anyone interfaced a PLC with a Control Techniques drive Nidec 750 using Modbus TCP? I am attempting to do so using an Automation Direct...
902
I'm involved in upgrading an IDEC FC5A-D12S1E PLC to a FC6A-D32P3CEE. I've attached the original layout of the system. Since then, another HG3G...
444
