iFix 5.1 Import / Export Database Problem - Excel
russg
Aug 2012
UK
275
When I export the csv file, display it in excel or notepad and then add some new tags that I've copied from current tags but changed the numbers I get errors when importing them back. And if they do allow the import I still get errors and not all of the fields are filled in, or some of the data is in the wrong place.
Does anyone know the best tool for doing this process?
I didn't record the errors. I've been reading up a little and just did what it says in the manual, that is to drag and drop to an excel sheet, then change it how I want it and drag it back. It kind of worked, although the database shut down due to it stopping working. I loaded the database back up and the new tags are there, but are missing the I/O addresses:
If there are no channel/devices in your IGS config that match your addresses, this will happen and is normal. Send an example of one of the addresses you are using
Yes, you're right. For some reason my IGS had lost all the tags i'd updated. Look better now thanks.
iFix is writing 0s to analog & digital outs after importing tags and restarting services. We don't see outputs in the ALM files, but it...
909
Hello everyone, Is there any solution to import tags which is in a format eg:- TI.2001, TAH.2001 etc while importing this to iFIX 5.8 it...
1,697
I have generated a CSV import file for my database but whenever I try to import, the DB editor just crashes. Is there a way to troubleshoot what...
3,535
Hi, anyone come across this issue before. I cant add new datablock to the S7A driver and when i try to import from a .csv this also fails! The...
2,070
Dear all, I am beginer in ifix hmi programming. I have 2 ifix 6.0 pc with license FiX and client.. Can some one tell me how to configure sample...
150
