IFix 5.8, SQL being used to trigger a bit.
Shiro485
Apr 2013
North Haven CT
103
Hello,
I have a project originally done in slc with an older version of ifix. A new rendition has been made and the plc project was migrated to logix 5000, using a compactlogix controller.
It appears they used sql to do alot of the sequencing before. There are bits that become energized (or are supposed to) depending on which step a sql database dbo.sequencedata.
Mission control lists sql connection as good and I can read variables fine.
For instance row 1 in the table
sequence 1` step 1 step address b23[100].1,
b23[100].1 needs to be closed to examine the step conditions. How can I use sql to energize a bit in plc?
I am using industrial gateway server to communicate between ifix and compactlogix.
Any pointer in the right direction would help greatly.
I have an existing Ifix PIC that is reading a SQL table when an down time timer times out. The operator clicks on the popup, choose a button with...
3,345
Hi, We are upgrading from fix32 to Ifix. We will be using SQL Server to hold and retrieve our alarm and Event data. 1.Can we also use SQL to...
4,123
I am using iFix 3.5 HMI/Scada. I created a new table in my SQL database. All of my iFix tags (SQD and SQT) are correct. When I trigger the event...
3,023
Dear all, I am beginer in ifix hmi programming. I have 2 ifix 6.0 pc with license FiX and client.. Can some one tell me how to configure sample...
148
Hello, I have to deal with iFix again and am looking at the most efficient way to create alarms to display in iFix, i.e. not creating an...
156
