iFix access element of array
jmveerkamp
May 2012
OH
23
I'm trying to get iFix 5.8 to access DINT and INT array elements from a ControlLogix.
My tag: test_dint
Data Type: DINT
Array Length: 100
My tag: test_int
Data Type: INT
Array Length: 100
I want to be able to assign an iFix tag to a specific array element, i.e. TEST_ARRAY_ELEMENT to test_dint[1].
When I do this, my Curr Value shows "????"
I have tried using @long and @float after the tag and neither seems to work.
Any ideas?
Thanks Garry,
I actually stumbled on those 2 posts before creating my own. I used the example to verify I can acess the bit test_dint[1].2 in a array of DINTs. But for some reason I can't access the entire DINT, test_dint[1].
Also strange is using the syntax I can access an array of INTs fine but not an array of DINTs.
Thanks harry. From the documentation on kepwares site I ended up getting the following to solve my issue:
For INT or DINT arrays in iFix:
-TEST_INT[0]{3}@WORD,1000 = an array of 3 starting at element 0.
-TEST_INT[1]@WORD,1000 = element 1 in the array
-TEST_DINT[2]{3}@WORD,1000 = an array of 3 starting at element 2.
-TEST_DINT[2]@WORD,1000 = element 1 in the array
Looks like my issue is I should've been using @word instead of @long.
Define a technical solution to generate an iFix database that will allow customer to capture A&E data A customer want to use an OPC based program...
2,036
hi all I would like to make a daily report on ifix SCADA. My need is to make a report inside a folder with current date and time using MS Access...
1,445
You help me with instructions. I'm not into sports in particular Ifix intelution 3.5 like this: I do not know how to write code to automatically...
2,390
Hi everyone, Sorry if I am a little vague but this question was ask to me by someone working on a system that I am not familiar with. Anyway...
26
17,224
Dear all, I am beginer in ifix hmi programming. I have 2 ifix 6.0 pc with license FiX and client.. Can some one tell me how to configure sample...
152
