iFix - Reading an array of Reals from ControlLogix via RSLinx OPC Server
BAJ
Jan 2006
Maple Grove, MN
201
Can anyone tell me the proper I/O address format to use for doing this? I've done this a million times with Modicon, but that driver doesn't require any special formatting.
I've got an array in the CLx PLC of 20 Reals I want to display in View. Here's what I've tried.
CT;Data;[CT]IFIX_RECIPE_FOOTAGE_STEP;No Access Path
CT;Data;[CT]IFIX_RECIPE_FOOTAGE_STEP[0];No Access Path
CT;Data;[CT]IFIX_RECIPE_FOOTAGE_STEP[0],L20;No Access Path
CT;Data;[CT]IFIX_RECIPE_FOOTAGE_STEP[0],R20;No Access Path
CT;Data;[CT]IFIX_RECIPE_FOOTAGE_STEP[0],F20;No Access Path
I can't seem to find any literature on this, google searches gave me some ideas but nothing worked. The first two produce the same value (element 0) for all array references in View (.F_0, .F_1, .F_10, etc.). The last three result in ???.
Thanks,
-Brad
Yes, Its a delayed reply!!!
Eg:
Assign "CT;Data;[CT]IFIX_RECIPE_FOOTAGE_STEP;No Access Path" to a Register(AR or DR) tag in iFix database, say 'TAG1'.
To view this value the normal procedure will be connecting TAG1 to a data link stamper, Source address format will be like 'FIX32.NODENAME.TAG1.F_CV'. As it is a register value, you have edit it little bit like,
FIX32.NODENAME.TAG1.F_0
FIX32.NODENAME.TAG1.F_1
FIX32.NODENAME.TAG1.F_2
FIX32.NODENAME.TAG1.F_3 etc... and connect to data link stampers.
I recently converted a PLC-5 program to Controllogix and using iFix as the graphic interface. I seem to have trouble reading a string and...
3,719
I have an existing Ifix PIC that is reading a SQL table when an down time timer times out. The operator clicks on the popup, choose a button with...
3,348
I have a bazaar situation where an iFIX V4.5 existing installation is now not reasding all the IO in a serially attached SLC 5/05?? If you look...
3,614
Dear all, I am beginer in ifix hmi programming. I have 2 ifix 6.0 pc with license FiX and client.. Can some one tell me how to configure sample...
154
Hello, I have to deal with iFix again and am looking at the most efficient way to create alarms to display in iFix, i.e. not creating an...
161
